Re: Electronic Ignition
Posted by Doug in OR on October 28, 2003 at 07:09:11 from (12.225.61.140):
In Reply to: Electronic Ignition posted by John in NE on October 28, 2003 at 06:27:56:
I use the Pertronix electronic ignition on an M. It works just fine. I did convert to 12 volts, negative ground, though. You might want to check a few other things first. First of all, are the points well-grounded? Rust and corrosion where the points are screwed into the distributor can cause resistance - resulting in low coil voltage. Are all electrical connections nice and tight and clean? Check everything in the ignition circuit. Is the coil good? A bad coil can fool you. Put a voltmeter on the ignition coil too - with the points closed. You should have nearly 6 volts on the input side of the coil, and nearly no voltage (under .5 volts) on the side going to the points. If you have a bad coil or poor ignition connections, electronic ignition won't help you. I use electronic ignition because it is more maintenance-free. You don't want to use it to mask another problem.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
