Re: 560 Diesel to gas engine
Posted by Randy in NE on October 28, 2003 at 15:12:51 from (68.99.25.85):
In Reply to: 560 Diesel to gas engine posted by Airtime on October 27, 2003 at 18:28:50:
It will take more than replacing the head. There are different pistons between a diesel and a gas. You need to remove the fuel pump and put on a distributor and carburator. Chances are the openings are not all the same for these things. It would be best to either replace the entire motor or just trade for a different tractor. By the time you swap out all of the wiring it could become quite a project. Typically a diesel is cheaper to operate. With a block/tank heater on it you should not have any problems starting it even in extreme cold. Just my $0.02 worth.
Post A Followup
: Re: Re: 560 Diesel to gas engine
