Re: H Trans Fluid
Posted by Michael Soldan on October 28, 2003 at 15:31:35 from (216.46.130.27):
In Reply to: H Trans Fluid posted by Vince-WI on October 28, 2003 at 13:09:47:
Vince, Rusty Farmall is correct, that drain hole could be all clogged up and there is more sludge in there. You can dump a gallon of diesel fuel or varsol in the tranny at the fill hole beside the gear shift lever. Drive the tractor around for a while till it is good and warmed up, you won't hurt the tranny just driving around, then pull the drain plug and use a device to unclog the area around the drain hole. Also check under neath the rear end and make sure there are no cracks in the housing. These can be welded by professionals if necessary. Ice in a tranny could cause a problem if someone tried too hard to move the tractor. In one H I bought I drained over a gallon of watere out of the rear, my other H had the worst sludge you coulld imagine. I don't advertise for anyone but I found Walmart had the best by on rear gear oil at about $29 for a 5 gallon pail. Good luck, slush it out, fill it up and the H will be fine....Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
