Re: H Trans Fluid
Posted by Fred on October 29, 2003 at 04:34:39 from (66.168.91.91):
In Reply to: H Trans Fluid posted by Vince-WI on October 28, 2003 at 13:09:47:
I have a tractor that I bought for parts that has a small hole in the trans. case that water got in. A few days ago I took out the PTO shaft and the oil is like grease in a grease gun. It will not come out at all. If yours has had the water in it for a long time it may be like that. Take the PTO out like the other man said and then wash it out with diesel fuel. You will want to look at the bearings to see if they have rusted. If you look in there and it is gummed up really bad you might want to take the top off the trans. and clean it out really good. It is not that bad a job and could save you a lot of money later. Good luck.
Post A Followup
: Re: Re: H Trans Fluid
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
