Re: Re: Re: Re: 460 wiring
Posted by ken on October 29, 2003 at 18:33:30 from (216.16.92.228):
In Reply to: Re: Re: Re: 460 wiring posted by Adam on October 29, 2003 at 18:26:04:
the purpose of the ballast resistor is to cut down voltage to the coil when running to like 7-8 volts.when you start you need to bypass the resistor to put a full 12 volts to the coil for a hotter spark. to do this there is 2 little terminals on the solenoid one is start and on is for the bypass wire to the coil.as you look at the solenoid from the back of the starter the little one on the right should be for start and the one on the left for bypass.
Post A Followup
: Re: Re: Re: Re: Re: 460 wiring
