Re: Done! ...or maybe not...
Posted by Ernie Bob on October 29, 2003 at 22:55:04 from (198.81.26.207):
In Reply to: Done! ...or maybe not... posted by David in UT on October 29, 2003 at 06:56:07:
David;
I had the same problem with my 200. I replaced the clutch disk, pressure plate and through-out bearing. The one thing I didn't replace was the pilot bushing. I tried all the tricks of driving it, letting it run with the clutch engaged for a while and I ended up slitting the tractor again and replacing the pilot bushing. I put a small dab of molly grease on it when I put it back together and it solved the problem. I learned a good lesson and that's replace everything, better than having to split the tractor again for a $2.00 part.
Good Luck!
Ernie Bob
Post A Followup
: Re: Re: Done! ...or maybe not...
