Re: 460 wiring
Posted by Gary in MOOzarks on October 30, 2003 at 03:06:04 from (64.240.21.157):
In Reply to: 460 wiring posted by fred on October 29, 2003 at 18:13:49:
Looks like you are getting lots of advise which is good, but can be just as confusing. What most of these fellows is true, it just depends on how you want to go about it. Running 12v through your coil gives a hot spark but its hard on points which is why they ran them at 6 volts nominal with 12 volts at startup. The older setups used an 6 volt coil with an external resistor, which was simple. When the switch was in start mode it ran 12 volts to the coil and in the run mode it ran 6-8 volts. Later they built coils that had an internal resistor and didn't use the ceramic resistor. like the one fellow said. Read the outside of the coil. They often say 12v external or something like that. Which means it's a 6volt coil for a 12 volt system. As far as the altenator goes, alot of folks use the one wire system which is easy to hook up but they are a bit more pricey. I generally use the 3 wire variety which are readily available and cheap. It does require a small light bulb like a running ligt or turn signal bulb to excite the altenator but that ends up on the dash as an indicator that its working when you start up the light glows and when the altenator is charging it goes out. If i did it right there will be a link to a conversion site that has a diagram good luck
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
