Farmall Tractors Discussion Board
Re: Getting more power from a distilate Super M
Posted by Bob M on September 30, 1999 at 16:11:49 from (152.205.16.175):
In Reply to: Getting more power from a distilate Super M posted by Joe Berendzen on September 30, 1999 at 13:28:36:
Hi Joe - One way to get more power is to increase the compression ratio. Can raise the CR somewhat by replacing the stock distillate head with an SM gas head, or raise it even more by using an SM, 400 or 450 propane head. I'm sure there's
some antique pullers out there who can tell you more...
Bob M
Post a Followup
: Re: Re: Getting more power from a distilate Super M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
