Re: Done! ...or maybe not...
Posted by Big Don on October 30, 2003 at 08:32:06 from (24.101.196.223):
In Reply to: Done! ...or maybe not... posted by David in UT on October 29, 2003 at 06:56:07:
David,
Much as I hate to suggest it, I think you have warped the clutch disk when you were trying to pull it together and broke the block. The clutch disk will bend (or warp)with less pressure than it takes to break the cast on the block. If that is the case, you may as well take it apart now as later and replace the disk. For safety's sake, take it apart and fix it right.
Don
Post A Followup
: Re: Re: Done! ...or maybe not...
