Re: Electronic Ignition
Posted by TonyG on October 30, 2003 at 13:56:56 from (128.244.194.141):
In Reply to: Electronic Ignition posted by John in NE on October 28, 2003 at 06:27:56:
I replaced the ignition points with the electronic ignition module on my 1950 Super A, and I'll never go back. Nice quick starts, and unlike points, the spark is the same reguardless of cranking speed. No points to keep adjusted, no condenser to "wonder" about. As points wear, the engine performance changes until it finally gets to the point you tune it up. With the module, performance dosen't deterioriate (except for plug wear).
T.
Post A Followup
: Re: Re: Electronic Ignition
