Re: Re: Re: Re: Why won't these sleeves budge?!!
Posted by Bob on October 30, 2003 at 21:53:35 from (66.163.134.177):
In Reply to: Re: Re: Re: Why won't these sleeves budge?!! posted by TP from Central PA on October 30, 2003 at 18:52:14:
The 8N has thin "dry" sleeves that fit in a semi finished bore, and are not exposed to coolant to rust them in place.. The A has "wet" sleeves, and two packings or "o" rings at the bottom that ARE exposed to coolant, which usually seeps into the grooves, and rusts the whole thing tight. I have seen blocks with part of the "o" ring land ripped out by the rusty sleeve being pressed out. It sure could not hurt to weld a series of beads inside the sleeve, especially in the bottom 2 inches, where they are stuck the worst, and the place the block, well supported, upside down in a press and push them out with a thick steel place machined to closly fit the bottom (top in this position) of the sleeve. This is the type of job perhaps best left to someone with the proper equipment, if you do not have access to it, as a fee paid to a good engine man to remove the sleeves would probably be a lot more reasonable than a replacement block! Using a sleeve puller which presses down on the top of the block could possibly break the upper deck if the load is not spred over a wide enough area.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
