Re: Farmall 100 charging post #2
Posted by John T on March 30, 2009 at 19:42:31 from (66.244.97.31):
In Reply to: Farmall 100 charging post #2 posted by chad from michigan on March 30, 2009 at 19:15:24:
If its a Voltage Regulator system and it charges fine if you dead ground the gennys FLD post but NOT otherwise, that tells me 1) The genny is okay and 2) The cause of non charging is EITHER a bad or mis adjusted VR,,,,,,,or the VR isnt well grounded,,,,,,,or the wires bad from the gennys FLD post to the VR's FLD terminal..
Sure the VR is compatible with your ground???
Was the genny correctly polarized before start up cuz if not the VR can get damaged????
DO NOT jump the VR's FLD and GEN/ARM terminals, if you wanna jump anythign try jumping the gennys FLD post to ground cuz that makes her high charge
Heres my Troubleshooting Procedure, if you work through it the cause of non charging can be determined
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=jd&th=304795
John T
