Re: IH 454 gas. broken gear shift arm. HELP!
Posted by Bernard le mécano on November 02, 2003 at 13:52:53 from (66.110.142.3):
In Reply to: IH 454 gas. broken gear shift arm. HELP! posted by Hurley Hughes on October 29, 2003 at 17:35:48:
Hi Hughes, you can chance this part by removal of the muti-control valve. It's on the left side of your tractor, under the hydrolic filter. Drain all the oil, remove pipe and PTO linkages,all the 3/8 bolts around the cover. With a short 7/8 open wrenche , you can remove the nut securing the gear shift lever. Put a new gasket and O ring when replace the valve
Bernard le mécano Québec Canada
Post A Followup
: Re: Re: IH 454 gas. broken gear shift arm. HELP!
