Re: Rough running M
Posted by Bill Smith on November 02, 2003 at 19:30:06 from (63.147.130.156):
In Reply to: Rough running M posted by Ty on November 02, 2003 at 18:53:27:
The firing order is 1342 and 1 is suppose to be timed with 1 on distributor cap. But you are right, doesn't make any differense which prong on the cap you time number one to, as long as the firing order stays the same and starts where you timed number one at. Sounds like you got a non original air filter. Easy way to rule out any problem there is to disconnect it from carb and run tractor without it hooked up to see if problem is still there. If that isn't the problem, I would make sure the tractor is timed correctly. If making some changes there, it might be a good time to go ahead and retime the engine to number one on distributor cap with number one cylinder. If timing checks out, I would bet it is either in the carb, or ignition system. Never been around that electronic ignition system myself.
Post A Followup
: Re: Re: Rough running M
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
