Re: what gear to pull in
Posted by ny bill o on November 03, 2003 at 08:26:54 from (66.24.251.92):
In Reply to: what gear to pull in posted by Bryce Andreasen (Magnum) on November 02, 2003 at 20:06:29:
i've pulled my 1456 a little in 5mph paced class, 11500#, hard track. i started out using low 4, spun out. next time, hi 1, spun out again. last time i pulled it in hi2 and used the ta back until i got most of the way to where the sled was stopping tractors, then pushed it ahead and hit throttle. did the best that way.i only take it to 1 pull that i can drive to- the 14 is too heavy for my trailer to go farther away. it is stock hp.
Post A Followup
: Re: Re: what gear to pull in
