Re: buzzing nose when key is turned
Posted by Bigdog on November 03, 2003 at 14:55:28 from (24.160.186.42):
In Reply to: buzzing nose when key is turned posted by farmallsc on November 03, 2003 at 13:43:37:
Your dead battery is overloading your charger. On the run or start settings, those chargers can put out a lot of current if the load is there. A dead battery is quite a load, in fact, the plates could be shorted. This is one reason not to charge a completely dead battery on a high-charge setting. This is causing the overload on the charger to trip. Get a new battery. This one isn't likely to take a charge.
Post A Followup
: Re: Re: buzzing nose when key is turned
