Re: Charging is this right?
Posted by chad from michigan on March 30, 2009 at 19:56:00 from (67.142.164.24):
In Reply to: Re: Charging is this right? posted by John T on March 30, 2009 at 19:49:38:
I know it wont show a charge with that gen/arm wire un-hooked but I wanted to show what the tractor was at when it was pulling a discharge to run. I then hooked it back up to take readings at the battery. it was at 8.4 non running and at 8.50-8.6 running.
Yes I am confused at the amp gage that is reading amps. What should that be at compared to volts? if the tractor is running with low charge rate what should the amps be? If it shows 10-12 amps at high charge that is ok? If it was volts it would over load the battery then I am sorry I was getting myself confused. I am sorry for all the questions.
