Re: SM 12 volt
Posted by Dan on November 03, 2003 at 22:11:39 from (12.18.162.170):
In Reply to: SM 12 volt posted by Likes Red on November 03, 2003 at 20:04:00:
I had the ballist resister go bad on my SMTA with 12 volt conversion last summer. It would suddenly die and could be restrted. Pulled it loose and found it had burned out. Put a new one on and works good. If you go to a different coil you will need a 12 volt with internal resister. Much more expensive thatn the ballist resister to replace.
Post A Followup
: Re: Re: SM 12 volt
