Re: Have you used stepped head pistons in an A?
Posted by gene b on November 04, 2003 at 03:23:26 from (67.1.104.76):
In Reply to: Have you used stepped head pistons in an A? posted by Brad on November 03, 2003 at 04:50:35:
There is a difference in the height of the dome from brand to brand. Put a set of hi-dome CONFORMATION pistone in and had to go to a DIST so it would start. These were the FIRE-CRATER type. Former I=H mech also told me there was a directive from I-H that when using FIRE CRATERS you would need to change from MAGNETO to DIST.
Post A Followup
: Re: Re: Have you used stepped head pistons in an A?
