Re: switch on battery on 40 B
Posted by Haas on November 04, 2003 at 11:06:20 from (12.65.79.14):
In Reply to: switch on battery on 40 B posted by smcIN on November 03, 2003 at 17:56:23:
Easiest is to just disconnect the ground cable from the battery. Key for that is a 1/2 inch box end or combination wrench. If you have a cover on your battery box, you can disconnect the ground cable where it is attached to the tractor chassis. If you want to be double sure, just take the ground cable off completely and put it in a safe place.
Post A Followup
: Re: Re: switch on battery on 40 B
