Re: Have you used stepped head pistons in an A?
Posted by Brad Sanders on November 04, 2003 at 11:35:59 from (168.8.170.13):
In Reply to: Have you used stepped head pistons in an A? posted by Brad on November 03, 2003 at 04:50:35:
Thanks for the information. Since I have a starter and
battery/distributor ignition I will definitely go with 3 1/8
overbore and stepped head pistons.
Post A Followup
: Re: Re: Have you used stepped head pistons in an A?
