Re: Re: Cracks in hood ?
Posted by Kevin (FL) on November 05, 2003 at 08:09:57 from (12.94.103.5):
In Reply to: Re: Cracks in hood ? posted by Chuck TX on November 04, 2003 at 11:14:31:
Chuck, Drill a 1/8" (or a little larger) hole at the end of the crack. That'll usually stop the crack from spreading further. Grind open the two edges of the crack to open it up. Place a piece of clean steel on the underside to provide a backing plate. This can be any thickness, but not more than 1/8" or so. Stick, MIG, TIG or gas weld the crack. Start at the drilled hole but don't run all the way to the end of the crack. Stop about 1/4-1/2" from the end and let the metal cool. Clean up (grind) the last part of the seam and when cool, complete the weld. Grinding is still required to smooth the bead. You can also take a pick hammer and tap the area a little lower that the hood surface to provide an area for body filler. Alway hit the "body filler area" with a 32 or 40 grit sanding disc to provide a good anchor for the body filler. Then go from there with the standard body work process. The backing plate should not be used where it would be visible when the hood is installed. The plate provides a "heat-sink" and reduces distortion of the hood in way of the repair. I've also brazed these cracks with good success.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
