Re: LOW OIL PREASURE
Posted by justin on November 05, 2003 at 16:43:29 from (216.188.198.180):
In Reply to: LOW OIL PREASURE posted by MARK ANDREWS on November 05, 2003 at 16:35:23:
Did you check the main and rod bearing clearances when the pistons & Sleeves were installed? These clearances should run 1.5 to 3 thousands clearance. Other possible problems are a warped sump plate on the oil pump, and or a weak oil pressure regulaing valve/spring combination.
Post A Followup
: Re: Re: LOW OIL PREASURE
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
