Re: steel wheel Farmall
Posted by ff316 on November 06, 2003 at 18:24:18 from (207.246.76.119):
In Reply to: steel wheel Farmall posted by Lee on November 06, 2003 at 10:07:45:
I've got to agree, around here you cold get it hauled for about $50.00 on a roll back which is not much to pay for a tractor. If you get it hauled, check with the driver before he comes and see if it's OK to leave the lugs on the rear wheels or if he wants them taken off. It would probably be easier to load with the lugs off. The steel lugs are probably just bolted on to the wheel. Good luck, looks like a heck of a project.
Fireman in KY
Post A Followup
: Re: Re: steel wheel Farmall
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
