Re: lock up rearend on a 656
Posted by Hugh MacKay on November 07, 2003 at 03:41:23 from (216.208.58.151):
In Reply to: lock up rearend on a 656 posted by Brian Jordan on November 05, 2003 at 19:29:57:
Brian: The first place I would look is bull gear and pinion shaft and gear that drives the bull gear. That pinion shaft being the same shaft as the brake shaft. Probably the quickest thing right now would be take brake apart, the problem could if your lucky be right there. If your brakes are worn to point where the caliper opens too far your brake could be on and will not release. That is quite easy and economical to do. It might be differential but I doubt it.
Post A Followup
: Re: Re: lock up rearend on a 656
