Re: DT414 cavitation question
Posted by RPM on November 07, 2003 at 08:30:09 from (209.152.115.185):
In Reply to: DT414 cavitation question posted by Chad on November 04, 2003 at 07:16:59:
I doubt that cavitation erosion of your sleeves is the problem, your crankcase oil would turn to gray fluid that does not lubricate the crank, I have seen this many times, if you have erosion it will leak into oil pan, this is caused by the microscopic burst of bubbles eroding holes in the sleeves outer surface where coolant circulates. As far as temperature goes if its not boiling out coolant then its not really hot, guage or sender could be reading a little low/high.
Post A Followup
: Re: Re: DT414 cavitation question
