Re: Steer Horns
Posted by F-Dean on November 07, 2003 at 12:26:29 from (12.74.46.2):
In Reply to: Steer Horns posted by Ted on November 07, 2003 at 04:49:48:
These guys are right. It can be a messy job for an experienced cattleman. For some reason, I always ended up as the person shoving the calves into the de-horning chute!
You might consider putting weights on the ends of the horns to turn them down and make them less dangerous. Also, the process is less dangerous.
Post A Followup
: Re: Re: Steer Horns
