Re: Re: charging 6 volt battery
Posted by RayP(MI) on November 07, 2003 at 14:33:58 from (216.46.197.227):
In Reply to: Re: charging 6 volt battery posted by Jake on November 07, 2003 at 06:52:15:
Jake is right - but, as battery gets up to fully charged, the current through the resistor drops, and the voltage applied to the battery gets very close to the maximum charging voltage at the 12 volt setting: Somewhere approximately 15 volts. This will cause your battery to heat, and boil off the electrolyte, and cause damage to the battery plates. Use a 6 volt charger for 6volt battery!
Post A Followup
: Re: Re: Re: charging 6 volt battery
