Farmall Tractors Discussion Board
Re: Cub Lo-Boy 154 - Loose Steering
Posted by Myron Bounds on October 01, 1999 at 19:45:46 from (216.60.176.158):
In Reply to: Cub Lo-Boy 154 - Loose Steering posted by Greg Faust on September 30, 1999 at 09:05:02:
Mine had to be stiffened by a good welder. The LoBoy 154 part(s) #s are:
1) Support assembly, Steering Lever: 404-597-R1 (this is the "bracket" that bolts to the frame on both sides just in front of the oil pan)
2) Lever, Steering: 404-600-R1 (this is the "L" shaped machined casting that your draglink rod & tie rods connect to)
3) Don't know costs of the above. Your nearest Case/IH dealer should be able to accomodate you.
Myron
Post a Followup
: Re: Re: Cub Lo-Boy 154 - Loose Steering
