Re: B275 hydraulics
Posted by parts man on November 07, 2003 at 21:36:09 from (207.179.175.7):
In Reply to: B275 hydraulics posted by jdp on November 07, 2003 at 19:39:00:
On the front of the unit under the seat, toward the left hand side when facing forward, is a plug, 1" to 1 1/8" wrench fits. remove and thread in pipe nipple/ elbow. Either 1/2 or 3/4, (I forget which). Run a Rubber pressure line to the back and put on a quick coupler. The return goes into the top of the hyd tank where you add oil, thread in a Tee, and put a quick coupler into the horizontal opening, and a plug into the vertical.
To use the outside couplers, set lift arms to desired height, thread in valve handle opn right side of unit, lift valve now controls outlets.
PS it's a good idea to shut off engine before turning in valve or uncoupling hoses at the back. If you have the lift lever in the lift position when the hose is uncoupled you can split the hyd pump!!
Post A Followup
: Re: Re: B275 hydraulics
