Re: Re: Farmall and Halloween
Posted by David in UT on November 08, 2003 at 09:48:09 from (63.187.16.8):
In Reply to: Re: Farmall and Halloween posted by Greasy John (Or) on November 08, 2003 at 06:36:54:
Hey there Greasy John, I used a Sharpe HVLP gun and PGP's acrylic urethane for the top coat. I used their epoxy primer for the base coat on everything. The grill, hood, and gas tank got several iterations of bondo, sanding, then a sanding primer over the top. I made sure that I put the top coat on within 72 hours of the epoxy primer -- apparently this will help the two coats bond together chemically. After that time, you'd have to scratch up the primer coat so there would be a mechanical bond between the coats. A lot more work, eh? Actually, I put the top coat on only an hour or two after I finished the primer, at least on the chassis. I also pulled *everything* off the tractor and painted in separately. That made it easier to get a good glossy coat all around things like the oil filter housing, the fan blades, etc. The chassis is pretty easy to paint...the roughness of the cast iron makes it almost impossible to run the paint on. I found it much harder on something like the hood, which would have a vertical side no matter how I positioned it. I had to be really careful to treat the verticals gently...the HVLP gun will put out a lot of paint. I found two things were really important -- first, I spent *a lot* of time working the metal before I painted. I think I probably did 4 or 5 iterations of bondo/sanding/primer on the sheet metal before I could be certain I had really gotten it smooth. Second, I could have used twice the amount of light in the garage when I painted. It got really hard to see when I had put on just enough paint to get the shine. I wear glasses too, so trying to see through the paint fog, safety googles, and my glasses got really hard at times... Hope that helps! - David
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
