Re: Steer Horns
Posted by Jimmy King on November 08, 2003 at 11:00:31 from (63.189.0.48):
In Reply to: Steer Horns posted by Ted on November 07, 2003 at 04:49:48:
When I used to buy Holstein Steers 350-450 lbs. alot of the time I would clip them off about 4 inches with hedge trimmer shears, that seems to kill the horn and leaves a blunt end. Caution reading between the lines, do not make pets out of cattle they can be very dangerous even without horns.
Post A Followup
: Re: Re: Steer Horns
