Re: Super M storage
Posted by Doug in OR on November 08, 2003 at 17:42:55 from (12.225.61.140):
In Reply to: Super M storage posted by Chad on November 07, 2003 at 18:46:53:
Stabilize the fuel. Make sure the fuel in the carb bowel is also stabilized (run to tractor for 20 mins or so after putting the stabilizer in the gas tank). Change the oil and filter. If possible, try to lift the tires off the damp ground or cold concrete. Remove the battery and store it in a warmer place, if possible. Recharge the battery every month. Remove the spark plugs and shoot a couple streams of oil in each cylinder and turn the engine over a couple turns. Be sure that your anti freeze mixture is strong enough to prevent freezing. Cover your exhaust stack. I guess that about covers everything. Somneone will chime in if I did miss something.
Post A Followup
: Re: Re: Super M storage
