Farmall Tractors Discussion Board
Re: Cylinder rust
Posted by Farmer Bob on October 01, 1999 at 21:27:15 from (207.227.185.17):
In Reply to: Cylinder rust posted by Ben on October 01, 1999 at 19:28:20:
Ben, I would recommend bore scoping the sleeves to ensure they are still within tolerance. Then before reassembly, spray light oil into the sleeves and use a cylinder hone to "buff" up the sleeves. Of course this requires removal of the pistons first which gives you a good reason to check the rings and bearings. You want to make sure there is not some damage to the rings in those cylinders with the rust. Good luck.
Post a Followup
: Re: Re: Cylinder rust
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
