Re: Re: need help! 806 pto removal
Posted by Jimmy King on November 09, 2003 at 19:47:25 from (63.189.8.52):
In Reply to: Re: need help! 806 pto removal posted by twopop on November 09, 2003 at 19:18:52:
Just a hint the suction tube for the hyd. angles down to the bottom of the housing, so tip the back down to clear it. Also get two bolts the same size of the bolts that hold the unit in, about 8 or 9 inches long and cut the heads off screw them in two of the holes to slide the unit on when replacing it makes it a lot easier to put bolts back in.
Post A Followup
: Re: Re: Re: need help! 806 pto removal
