Re: need help with H flooding
Posted by Allan on November 10, 2003 at 03:23:13 from (148.63.132.164):
In Reply to: need help with H flooding posted by Bindernut on November 09, 2003 at 22:29:22:
Binder,
I think your carb is probably just fine.
Seems like these old gals all start the same and will all do what you are describing if you are trying to start it cold with a closed or nearly closed throttle.
The key is in the throttle because if it is closed (or almost closed), it won't allow the engine to get enough air.
When she is cold, crack the throttle to 1/2 or 2/3, choke it, and just as soon as it starts, push the choke completely back in. Then, you have to "work" or "feather" the choke just a little 'till she levels out.
They just can't stand a lot of choke (even when they are cold), especially with the throttle closed down.
That's been my experience anyway,
Allan
Post A Followup
: Re: Re: need help with H flooding
