Chad, John's posts on generator/regulators are the easiest/simplest explainations I've seen. An AMP guage shows AMPERES NOT VOLTS. You should NEVER spark the Field and Gen terminals, you may have cooked the regulator. A quick test of the regulator is to ground the Field terminal; this should give you as much as the generator can put out, don't leave it to long or you will burn up the generator.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
