Re: Cub w/wheel weights
Posted by Bigdog on November 10, 2003 at 15:00:41 from (24.160.186.42):
In Reply to: Cub w/wheel weights posted by Small Battle on November 10, 2003 at 13:48:12:
Rear wheel weights are about 150 lbs each, Fronts are 25 lbs. each. The tractor with hydraulics and no fluids in the tires would be around 1500 - 1800 lbs.
Post A Followup
: Re: Re: Cub w/wheel weights
