Re: Re: Lets talk tire chains
Posted by Randy in NE on November 11, 2003 at 06:53:17 from (216.58.237.20):
In Reply to: Re: Lets talk tire chains posted by Red Barron on November 11, 2003 at 06:07:14:
If the chains are installed properly they will not lay down in-between the tread patterns. We used chains on an H and a Case 300 when I was a kid. Made a world of difference. We usually turned the blade around backwards and pushed in reverse. Not bad for a teenager. Not so easy now that I am middle aged and have grown around the waist. As long as the snow isn't packed a good set of tires will get you through a lot of snow. A couple of times getting stuck and digging/pulling the tractor out you may find that it isn't so expensive purchasing a good set of tire chains.
Post A Followup
: Re: Re: Re: Lets talk tire chains
