Re: H Burning Points
Posted by Rich on November 11, 2003 at 15:46:12 from (69.66.98.6):
In Reply to: H Burning Points posted by Walter on November 11, 2003 at 15:03:55:
Point gap on Dist.should be .020. Are you runing 12 volt? If so you need a resistor in the line from switch to coil if you are still useing the 6 volt coil. If you are useing 12 volt coil put res.between coil and dist. Just my thoughts.
Post A Followup
: Re: Re: H Burning Points
