Re: what is distillate???????
Posted by Steve - IN on November 11, 2003 at 21:37:14 from (12.222.30.13):
In Reply to: what is distillate??????? posted by ronda on November 11, 2003 at 19:34:58:
ronda, All tractor fuels are "distilled" or burned off from crude oil. The lighter stuff with fewer carbon molecules, like paint thinner, comes off first. Then you get gasolines with 6,7,8,9 carbon atoms per molecule. Then comes the heavier fuels like kerosene (a.k.a. distillate) with 11 to 14 carbons atoms per molecule. Then come heavier fuels like Diesel and heating oil. Then the heavy stuff like motor oil, and asphalt are last in line. When that distillate tractor was built, there was more demand for gasoline in cars than there was for kerosene - so it was a lot cheaper then than gas. Now that we have turbine jets that burn kerosene, the price has gone up. There's little savings in burning kerosene anymore. When distillate did mean fuel cost savings, you had to modify the engine to burn kerosene. First it is easier to start on gas than kero, so you see two tank and a switchover valve on the kero engine. Second kero has more carbons per molecule than gasoline - so you have to change the carb / intake to add heat so it stays as a mist and doesn't fall out as a liquid when it's cold - so you had to add ducts to heat the carb/intake manifold. Next and last, kero has more hydrogen atoms per molecule than gas - so it makes a bigger explosion when it does fire. The engine is basically an air pump. So if the amount of explosion is greater, you have to make less pressure in the air pump (called compression ratio in an engine) to compensate. They used to say better living through chemistry - that may not be true - but different engines from different chemistry surely is.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
