Re: Lets talk tire chains
Posted by Pete L on November 12, 2003 at 06:32:24 from (198.36.89.4):
In Reply to: Lets talk tire chains posted by Gramps544 on November 10, 2003 at 17:39:16:
My dad has been plowing with his Jubilee for a couple decades now in northern Michigan and not with chains. He's used a back blade, pulling the snow. Very rarely does he push due to dangers to the blade, and besides, 3-point hitches are designed to pull. Hitting something solid may damage your blade or 3-point system. Terrain is pretty flat in his area. You might want to put some shoes on a back blade though. It will dig deeper into your driveway than you want. We took some 1/2" X 3" flat bar, bent up a couple "C" shapes, and pinned them thru the grader blade. Spaces up the blade some and work fine.
Post A Followup
: Re: Re: Lets talk tire chains
