Re: H rod bearing
Posted by Walt on November 13, 2003 at 08:27:16 from (66.119.33.170):
In Reply to: H rod bearing posted by Bill on November 13, 2003 at 05:29:14:
Bill, before you button up the bottom end check the main bearing clearances!!! If they are at or above the max clearance replace them too. Loose main and tight rods can and will take out the rods from oil starvation. Good luck
Post A Followup
: Re: Re: H rod bearing
