Re: Re: Adding a 1 point fast hitch to a 53 Farmal
Posted by Randy 64 Cub on November 14, 2003 at 04:22:37 from (192.222.69.2):
In Reply to: Re: Adding a 1 point fast hitch to a 53 Farmall Cu posted by Hugh MacKay on November 14, 2003 at 01:30:43:
You will not be able to install the helper spring, but everything else will install just fine. The fast hitch wasn't incoperated to cubs until 1954. Unless you are using a fast-hitch 42A or 59A woods REAR mower you wont have a problem lifting most implements.
Post A Followup
: Re: Re: Re: Adding a 1 point fast hitch to a 53 Farmal
