Spool Valve on Farmall M
Posted by Marlin on November 15, 2003 at 08:10:28 from (12.219.50.128):
The local Farm & Home store had a 20% off sale today, so I picked up a hydraulic control valve with the intention of using it as a spool valve to make the cylinder on the 3-point into a 2-way. When I got home and started reading the instructions, I discovered the statement "This valve does not incorporate a load check so it is not intended for metered lifting applications or heavy loads". The valve is apparently designed to be used on a log-splitter, but will this valve work for my application? I usually don't lift anything heaver than a 7 foot blade.
Post A Followup
: Re: Spool Valve on Farmall M
