Re: H-4 magneto
Posted by Brad L on November 15, 2003 at 16:18:36 from (63.226.132.18):
In Reply to: H-4 magneto posted by matt Sheaffer on November 15, 2003 at 11:49:47:
Have you set the gap on the points correctly .013 to .020 will work. I think its .013 though. Did you check your condensor?If you measure it with an ohm meter it should move the meter a little bit while it charges and the will go back to an infinate reading.If you read nothing or a resistance constantly its bad.ALSO check points for pitting or corrosion.If none of that works it could be the coil in the mag itself.
Post A Followup
: Re: Re: H-4 magneto
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
