Re: for hugh mackay
Posted by Hugh MacKay on November 15, 2003 at 23:39:33 from (216.208.58.173):
In Reply to: for hugh mackay posted by red cub on November 15, 2003 at 05:39:08:
redcub: Scotty has already given you the right answer, All off set Farmalls came from factory with heavy cast wheel center for the right and pressed steel for the left. That was to balance tractor only, from there you add same weight to each side.
People do some funny things with offset tractors. Some guys will actually buy a wheel so they are both the same. I bought a Farmall 140 just about a year ago. They had the left wheels of tractor set at maximum tread and the right wheels at minamum tread, of course thinking they were balancing the tractor. Not only did they throw the tractors balance off badly. I bet it wouldn't pull more than 65% of one set properly. Inside of rear tires same distance from fender very important.
Post A Followup
: Re: Re: for hugh mackay
