Re: Re: Condensation Inside M Engine
Posted by cheg on November 16, 2003 at 07:11:06 from (63.245.131.15):
In Reply to: Re: Condensation Inside M Engine posted by Wayne Swenson on November 15, 2003 at 19:16:03:
I bet I do not have the engine running hot enough. I recently rebuilt the engine so everything should still be correct. No corners were cut with the overhaul. I put a mechanical temperature guage on the tractor and am running at 135 degrees. On the road, it drops about 5 degrees.
Post A Followup
: Re: Re: Re: Condensation Inside M Engine
