Re: Farmall H remote control valve???
Posted by Randy in NE on November 16, 2003 at 19:38:33 from (68.13.173.75):
In Reply to: Farmall H remote control valve??? posted by John on November 16, 2003 at 19:13:53:
I believe that you have to lock the lift-all control rod in the pulled out position to get high pressure to the remote control valve. You will need to plumb the return line back to the sump. You can then run either a two-way or one-way cylinder. The one-way requires the weight of the implement to compress the cylinder. You just need to hold the control valve in the down postion and let the hydraulic oil drain back into the sump.
Post A Followup
: Re: Re: Farmall H remote control valve???
