Re: Re: Re: Farmall tractors
Posted by RAR/IA on November 17, 2003 at 08:48:29 from (207.28.65.241):
In Reply to: Re: Re: Farmall tractors posted by Harold H on November 16, 2003 at 17:13:13:
Dad's tractor was shipped by JD dealer truck (JD factory here at Ottumwa). Other tractor I found at JP salvage in Missouri. Tractor was from Louisana I believe. Rougher than I thought.
I thought I should have single rib front tires. Size is 7.50 x 18. Where could I find a set and $?
The steel wheeled 9 has 54" rears with extensions. Outer and inner rows of lugs are capped with welded ons because of wear. Does not have scrapers. Fronts were cobbled as the centers are for rubber tires. Thinking of parting out or would sell tractor as it is. Was a dual fuel version, start on gas run on distillate.
Don't have digital camera, yet. Could take with 35 mm and send. Phone is 683-1149. Figure out area code from other post.
Where are you?
Roger
Post A Followup
: Re: Re: Re: Re: Farmall tractors
